125cc Sportsbikes Forum: Normal Rs Running Noises - 125cc Sportsbikes Forum
#1 User is offline   Camefromthemoon
Posted 15 May 2017 - 05:48 PM
Could anyone do me a favor and take a listen to a video I took of the rs idling. Without hearing another, I've got nothing to compare it to. Ta in advance.
https://youtu.be/O-qzNbZjgyo
https://youtu.be/BMeaOb1tnNM
  • 125CCSportsBikes.com
#2 User is offline   AntelopeSam
  • 125cc Sportsbikes Mechanic
  • PipPipPipPip
Posted 15 May 2017 - 06:16 PM
Do you have the snorkels in your airbox?
It seems like its ticking over alright. I wish mine was that smooth/low
#3 User is offline   Camefromthemoon
Posted 15 May 2017 - 06:39 PM
Yep snorkels are still there, done the mod so the larger diameter holes are on the outside and cut away the inners. Had a nightmare getting the idle right before fitting the 34mm carb though. Reason I put this up is Im not sure if I can hear it knocking. Had barrel honed and a new piston from those good people at pjme about a month again ago which has scored slightly since above the exhaust port even after a load of heat cycles. Replaced the plastic gears last week which eliminated a load of rattles.
