125cc Sportsbikes Forum: De-Restricting your mito! - 125cc Sportsbikes Forum
3
  • (2 Pages)
  • 1
  • 2
De-Restricting your mito! So you wanna go faster huh >?
#1 User is offline   mito_martin
  • Proud Mito owner
  • PipPipPipPipPipPip
Posted 25 June 2006 - 06:33 PM
so do you get a lot more power by ONLY taking off the extra pipe on the downpipe and welding over?
#2 User is offline   Mito Revolution
  • 2 Strokes And I'm Happy
  • PipPipPipPipPipPipPip
Posted 25 June 2006 - 06:50 PM
no. you need to do everything in one go.
#3 User is offline   Chuck41
Posted 03 July 2006 - 08:52 AM
Firstly, Hi All!!
I race a '94 Mito Evo in the Post Classic series in Sydney, Australia. With no engine mods, a Jolly Moto pipe,and a 35mm Keihin PWK Carby, she puts out 31hp. I've recently put Boysen reeds in, but haven't had it back to the dyno yet. So, a couple of questions..
I've read on a Portuguese website that they're getting 50ish Hp from their bike. They've got a 41mm PWK carb, and a Gianelli pipe, but apart from that, it would be hard to guess what else they've done, Porting, running Methanol, etc. I'm also unsure of whether that 50HP is at the crank or back wheel. If it's at the wheel, I'm all ears!! Anyone else had these sort of figures from a Mito engine??, Is 41mm going to breathe easier, or will it drown the standard engine? Does anyone have any feedback on the Mitaka barrel and piston kits? would it be more beneficial to go to the later model head with the domed piston? (I'm currently using the standard flat top pistons)
Thanks in advance for your help.
Chuck
#4 User is offline   Mito Revolution
Posted 03 July 2006 - 10:30 AM
no way are they geting 50bhp form anywhere. mitaka a sh*t, use all cagiva parts.
#5 User is offline   Chuck41
Posted 06 July 2006 - 09:52 PM
Ok, straight to the point, No BS! Thanks.
Why is Mitaka sh*t? Do they have a history of failing? Or do they just not perform as well?
Can anyone shed some light as to whether Flat top pistons perform better than Domed?
Anything constructive, that will increase my current 31 Hp would be appreciated
#6 User is offline   Cagiva Gezzer
Posted 06 July 2006 - 10:10 PM
If the flat top is matched to the correct head it shouldn't make much difference when compared to a domed matched with a dome head.
Start a thread in the main mito section and you'll get more answers.
#7 User is offline   mike the bike
  • 125cc Sportsbikes Rider
  • PipPip
Posted 17 August 2006 - 06:13 PM
View PostCagiva_Kev, on Dec 30 2005, 06:06 PM, said:
ok so first of, this will take your bike to around 26-28 bhp at the rear wheel ! so if you've not road anything bigger than a restricted 125, take it easy... its not uber fast but its fast enough to catch you out..
ok so firstly, you have 2 options , you can either :
A: Have your original exhaust de-restricted (they usually have a cone in the downpipe, this has to be cut out, and then welded over)
or (my preffered option, and for best results)
B: Buy a race exhaust, ie jolly moto, jim lomas etc, this is a good choice http://www.125ccsportsbikes.com/forums//in...showtopic=20174
as these dont have any restriction in them....
ok, your about half way there, DONT take your bike out just yet, a couple more things you have to do for best results, firstly, you want a derestricted airbox lid and some appropriate jets, try craig for these, failing that try rob at mito mondo. As a general rule, your looking at around 10% bigger jets, older and newer mitos have different carbs so best to check with craig/mito mondo on which jets to go for.. you want to start a little big, and work your way down the jets... till you find the right one :)
How do i know if its jetted right you ask ?
for checking the MAIN jet is correct, you can either do it yourself ;
you need about a mile, where you can ride the bike flat out for a full mile, then you will need to pull in, hit the kill switch, dont let the bike rev down... or down through the gears just kill switch, then clutch in and stop....
now check your spark plug, black = jet too big, tanned brown = jet perfect, grey = jet too small (BAD) alter the jetting accordingly, and you good to go :)
you could get this done on a dyno, if your a little unsure yourself, for more info on jetting yourself, see http://www.amiles.co...PlugReading.htm or http://www.bcchapel....s/0003/pg11.htm
HTH
Kev
HI Kev Ive just bought a new Mito evo and i want to derestrict it Im putting in a 120 main jet do you think I should up the Low speed jet from 55 to 65 at the same time?
mike the bike
#8 User is online   Old Painless
  • Does not know Everything !
  • PipPipPipPipPipPipPipPip
Posted 20 August 2006 - 05:58 PM
For jets buy a derestriction kit from Rob at Mito Mondo, it has all you will need.
As has been said above, do all of the steps at the same time or ELSE will happen.
If you have specific questions ask them in the Mito forum as Gezzer stated above.
This post has been edited by Old Painless: 20 August 2006 - 05:59 PM
#9 User is offline   Laura
Posted 10 September 2006 - 10:10 PM
OMGAA! how complicated! i was gonna try myself but i don't think i will! i think ill take it a proper place, god this bikes robbing me! only had it six months and spent so much!
#10 User is offline   Cog Head
  • 125cc Sportsbikes Racer
  • PipPipPip
Posted 27 September 2006 - 11:55 PM
my 2000 reg mito has been de-restricted and has had a v-force 3 reed block fitted, but wont do the ton, what could be the cause of this? could it be the front sprocket being a tooth too small? of the carb set up dodgy (when i blip the throttle is bogs down) or has the exhaust been done wierdly ?
any help will be muchly apretiated. Brad...
#11 User is offline   NoobyMcdriver
  • 125cc Sportsbikes Tuner
  • PipPipPipPipPip
Posted 28 September 2006 - 12:04 AM
You could get a 154cc kit, port and polish, get a 39mm carb, fit a +5hp nitrous bottle, even fit a small go kart turbo unit, speed is a question of money.... how fast can you go?
#12 User is offline   Marci
  • 125cc Sportsbikes Mechanic
  • PipPipPipPip
Posted 02 October 2006 - 02:32 PM
Quote
I'm guessing this is the project he was on about... http://www.racingsm.org/mito125ev.php
Bearing in mind LuFo's 2T-tuning reputation, I'd be inclined to believe the almost-50bhp-at-the-crank figure... but I doubt anyone in this country could achieve it...
Quote
Read the link above - it's all down to who does the tuning and how, and twas a handmade pipe, handmade CDI, hand-ported polini cylinder... none of this "buy a bit from a shop and bolt it on" mallarky I'm afraid... if you want that much power, it's gotta be done by someone with the know-how. Twas around 44-47bhp at the wheel.
This post has been edited by Marci: 02 October 2006 - 03:50 PM
#13 User is offline   WRXBOX
  • PipPip
Posted 28 November 2006 - 10:50 AM
I thought this link would be good info in here
http://www.moto-one....ce/mito125.html
#14 User is online   Old Painless
Posted 13 February 2007 - 10:43 PM
As far as i have found out the 125cc mito squish volume should be 8.8 cubic centimetres, for a 162cc it should be 14.4 cubic centimetres.
Thats for those who are upgrading or rebuilding and want to measure the squish properly using a syringe and oil.
Make sure you remove the exhaust pipe before measuring the head volume with oil as it will run straight down into the exhaust and get stuck in the expansion chamber if you dont.
#15 User is offline   trajan
  • PipPip
Posted 23 April 2007 - 04:06 PM
maybe this is a stupid question but
can someon post a pic of a de-restricted airbox
caus i cant find any pics of it :blush:
#16 User is offline   cagivamitoevo
  • 125cc Sportsbikes Supporter
  • Group: Supporters
  • Location:Norwich Norfolk bikes:MitoevoII 125,Vfr400 job:nightshift supervisor
Posted 23 April 2007 - 04:24 PM
this is off my evoII bike plenty of sealant to stop leaks aswell lol
http://i159.photobucket.com/albums/t138/cagivamitoevo/DSC00299.jpg
hope this helps
#17 User is offline   M170 SAM
Posted 10 July 2007 - 04:52 PM
you know you could just buy a racing air filter like a K and N filter cheap and adds power! also, to an earlier question, have a look at dome topped wiseco pistons they are forged and so more revs are achieveable which means more horses! l8rs.
#18 User is offline   Cagiva4ever
Posted 17 July 2007 - 07:34 PM
Hi !
some nice photos:
Exhaust
http://www.motot.net..._hukkaputki.jpg
Air Box lid-Air intake snorkels
http://www.motot.net...o_imuputket.jpg
bye :)
markus
This post has been edited by Cagiva4ever: 17 July 2007 - 07:35 PM
#19 User is offline   MartinTheWookie
Posted 16 August 2007 - 12:56 PM
Hi Everyone,
Why is derestricting so bl**dy confusing?
I got myself a full Arrows system and have been dying to fit it but have been scared off by all the talk of running lean and killing my Mito.
I've been reading the info on here, but still not sure how to do this properly.
There's a guy selling bike parts on flea bay who said "re-jetting is the worst possible thing you could do to a Mito and it will never run properly again", and yet you lot say re-jetting HAS to be done.
I'm sat here with a full exhaust system, Boyesen Reeds and an induction air filter - all still in their packaging.
I've tried the famous Rob at Mito Mondo but we seem to keep missing each other or picking bad times to call.
I got absolutely wasted by a shell-suited chav riding a spanking new RS125 with squeaky clean L-Plates on it the other day, so something has to be done - rapid.
I don't want to fit a bigger carb or anything else too complicated - just to be able to fit my new bits without blowing the bike to bits 500 yards down the road!
While I'm trying to catch up with Rob, does anyone else know the proper tried and tested full de-restriction process and roughly how much it's going to hurt my wallet?
I ride a yellow 2004 Mito which I've owned from new and any help would be much appreciated.
I'm new on here so don't hurt me if I'm going over old ground!!!
Thanks guys
#20 User is offline   cagivamitoevo
  • Group: Supporters
Posted 17 August 2007 - 06:37 AM
right you need a airbox lid the same as the one in my post above don't use anything else it WILL kill your mito not sure on what jets u'll need maybe someone will be kind enough to imform you failing that if u cant get rob via telephone send him an email goodluck
  • (2 Pages)
  • 1
  • 2
