125cc Sportsbikes Forum: Fitting A New 34Mm Carb Help - 125cc Sportsbikes Forum
#1 User is offline   gavinh
  • 125cc Sportsbikes Racer
  • PipPipPip
Posted 08 April 2011 - 12:36 PM
I am. Fitting a dellorto 34mm VHSB carb on my 2000 aprilia rs 125 I wanted to know how many turns should the mixture screw be turned and how do I fit the 160 main jet? Also is there anything else o need to do?
  • 125CCSportsBikes.com
#2 User is offline   box
  • 125cc Sportsbikes Tuner
  • PipPipPipPipPip
Posted 08 April 2011 - 12:41 PM
i thinks its bout 2.5 turns out,to fit the jet
just unscrew the nut in the float cover, ie
the lower half of the carb you will see a brass
nut about 8mm across the hex with a small hole in, that is your jet
unscrew and refit your new one done back up the cover
nut
d
#3 User is offline   gavinh
  • PipPipPip
Posted 08 April 2011 - 12:57 PM
Nice one cheers will it make a lot of difference to the power?
#4 User is offline   pego30
  • 125cc Sportsbikes Team Legend
  • Group: Supporters
Posted 08 April 2011 - 02:53 PM
depeds what air filter and exhaust you have
if its a standard air box and a decat zaust or arrow equivelent you ideally want 155-158
if its a cone filter 162 - 165 main jet
if you have the standard air box put the 1 60 in and mve the needle clip to its highest position :thumbsup:
#5 User is offline   box
  • PipPipPipPipPip
Posted 08 April 2011 - 03:07 PM
oh yea, most of us with the 34mm carb
have to run with the needle on the top notch
or secound to top
d
#6 User is offline   gavinh
  • PipPipPip
Posted 08 April 2011 - 05:22 PM
It's a 2000 the so standard exhaust with no cat and standard airbox with pipercross flat filter and up 1 tooth on the rear sprocket and down one on the front
#7 User is offline   pego30
  • Group: Supporters
Posted 08 April 2011 - 05:42 PM
155 or 158 main
#8 User is offline   xtreamer
  • PipPipPipPipPipPip
  • Location:repaired 'n' running and now sold for silly money with sh*t loads of spares, gonna miss it :(
Posted 08 April 2011 - 06:20 PM
View Postpego30, on 08 April 2011 - 05:42 PM, said:
155 or 158 main
:thumbsup:
#9 User is offline   gavinh
  • PipPipPip
Posted 08 April 2011 - 09:08 PM
Cheers thanks just ordered those
#10 User is offline   GeorgeL
Posted 05 July 2011 - 10:02 PM
or secound to top
d
Is it worth upgrading from the 28mm carb? Noticable power increase?
#11 User is offline   box
  • PipPipPipPipPip
Posted 06 July 2011 - 12:55 PM
yea i would say it is much better midrange
with bit more top end power
d
