125cc Sportsbikes Forum: Rs 125 Suspension And Brake Upgrade - 125cc Sportsbikes Forum
#1 User is offline   kizza121
Posted 19 November 2011 - 03:53 PM
hi guys n gurls
well to start with hello to everyone im new on the forum and this is my first post lol
just wondering what suspension and brake ugrades there are for the RS125... im currently working on one (not sure of the model or year) and im hopefully putting a pegaso 650 lump in it and using it as a practice stunt bike. as the engines gonna be a little heavier and im gonna be liftin it up on one wheel alot i figured id need to upgrade the supsension aswel as the brakes. any help would be much appreciated
kizza
  • 125CCSportsBikes.com
#2 User is offline   chubbosaurus
  • Group: Supporters
Posted 19 November 2011 - 06:21 PM
rs250 front end would be sweet
#3 User is offline   kizza121
Posted 19 November 2011 - 07:28 PM
thats a thought i hadnt had... sounds like a job for ebay and the breakers yard... cheers bud
#4 User is offline   matthew017
  • 125cc Sportsbikes Tuner
  • PipPipPipPipPip
Posted 19 November 2011 - 09:30 PM
what bout some ktm forks or something?
#5 User is offline   pego30
  • 125cc Sportsbikes Team Legend
  • Group: Supporters
Posted 19 November 2011 - 09:32 PM
:ban:
#6 User is offline   matthew017
  • PipPipPipPipPip
Posted 19 November 2011 - 09:33 PM
why?
#7 User is offline   pego30
  • Group: Supporters
Posted 19 November 2011 - 09:38 PM
fitting ktm forks means youll need ktm wheels which in turn means you need a new speedo drive system as the rs speedo drive runs off the front wheel, not too mention you would need KTM brake callipers and discs, which in turn would probably need new master cylinders and levers, im not even sure if the ktm forks are 40 mm and will fit the rs yoke sso you may need a ktm top yoke and bott yoke
also ittl sit too high at the front as ktms are SM's
see why its silly now ?
This post has been edited by pego30: 19 November 2011 - 09:39 PM
#8 User is offline   matthew017
  • PipPipPipPipPip
Posted 19 November 2011 - 09:41 PM
yeah, i was only trying to be helpfull lol
#9 User is offline   pego30
  • Group: Supporters
best thing too do to the front suspension is use better thicker oil and/or fit an air valve on the right fork with 3 or 4 psi in the fork
also dropping them threw the yoke 10 mm helps produce a better angle of attack
as for the rear shock a sachs boge SP shock is what you want
or
a custom made maxton unit
This post has been edited by pego30: 19 November 2011 - 09:41 PM
#10 User is offline   1will1
  • 125cc Sportsbikes Rider
  • PipPip
Posted 19 November 2011 - 09:51 PM
why not a triumph 675 front end ?
it will look super tick
#11 User is offline   kizza121
Posted 20 November 2011 - 02:39 PM
thanks for all the help. ive spoke to a lad about some 250 forks and he's sure there 50mm and ive had a quick check of mine and they are 50mm so hopefully they will fit.
im not really too fussed how its going to look as its a low budget bike to practice on its gonna be bounced off the floor etc so cosmetics arent really vital.
i did look at the maxton shocks but they are big money from what ive seen. ive been looking at the 250 rear shocks and they look as if they will fit straight on.
kizza
#12 User is offline   Freddy
  • PipPipPipPipPipPip
Posted 20 November 2011 - 02:57 PM
kizza
Low budget? Surely fitting a new engine, forks, suspension, other parts that need replacing because of all the changes... Etc etc, will NOT be low budget?
And surely straining an RS frame with a 650 lump AND stunting isn't really the 'um... Best idea?
Would have thought it would be a lot cheaper to buy a used 600 stunter, or even just a cheap used 600?
#13 User is offline   pego30
  • Group: Supporters
Posted 20 November 2011 - 06:00 PM
:plus: :clap: threads full of of fail
#14 User is offline   kizza121
Posted 22 November 2011 - 11:50 AM
not really as i can do all the work myself. the only thing ill hav to buy 'stunt wise' is the handbrake and clutch leaver an then sprockets and chain the rest can be dont myself e.g. cage, wheelie bar etc... as for the bike itself if i can pick up the shocks and breaks cheap enough its just a case of finding a donor to go in it then again all the modifications to the frame will be done myself. it will make ideal stunter as being a 650 single it'll have plenty of grunt in a light wieght frame
buying a 600 then stuntin it would be more expensive i've spoken to a few people about it and looked into it. im lookin at spending under a grand on this project. and to get a 600 and stunt it or to buy one stunted already ur lookin at 1500+
kizza
#15 User is offline   matt p
  • 125cc Sportsbikes Racer
  • PipPipPip
Posted 22 November 2011 - 01:38 PM
or
what weight oil is best suited for road riding ?
#16 User is offline   pego30
  • Group: Supporters
Posted 22 November 2011 - 05:16 PM
depends on your weight the haynes says 10 - 20 W oil
i use 15 W
i have heard of different weight oils being mixed to suit before now
if your gonna drop the forks id suggest use a heavier oil then 10 W
#17 User is offline   matt p
  • PipPipPip
Posted 22 November 2011 - 05:21 PM
mine are dropped about 12mm, and i weigh 16.5 st ish.
some one once told me a few tricks on setting the suspension but i cant remember now. il give the 15w a blast
