Bottom End Locked - 125cc Sportsbikes Forum
125cc Sportsbikes Forum: Bottom End Locked - 125cc Sportsbikes Forum
Bottom End Locked
#1 User is offline   Fsmlittler
Posted 11 April 2021 - 02:27 PM
I’ve just finished putting a new barrel and piston on my Evo after a seizure. After a bit of faffing around with wiring I finally got everything connected and ready to fire up today. A couple of clicks on the starter and all seems fine as the motor span over. I then hooked up fuel and went to start up. Now the starter won’t turn over the motor-the starter is clicking and if I try and bump it the motor is locked solid. So I took the top end off and with no barrel on the motor still won’t turn over. Rocking it in gear doesn’t budge the crank.
I took the starter off in case that had somehow jammed but it still won’t budge
Help
