Mito Air Box Snorkel Modification?
#1
Posted 11 December 2020 - 03:27 PM
I will likely get my hands on a mito this coming week. I have done a reasonable bit of research on how to derestrict one. A new full exhaust and bigger carb will be installed but I'm lost on how to modify the air box. From what I understand the snorkel needs to modified in some way. Is it totally removed? Cut down somehow? Does anyone just sell a less restricted snorkel? Perhaps one designed for racing? Please help me out with this if you can. Thank you all very much!
#2
Posted 13 December 2020 - 03:43 PM
There are many variables here, first of all what year is your Mito? Most late Mitos in restricted version came with the DellOrto 28, you don't need a bigger carb to derestrict it, just change jets and adjust needle etc. plus make the specific changes in the airbox and exhaust, it's all well documented. If you mean instead that you want to go for a bigger aftermarket carburetor (F.e. DellOrto 32 or 34) or even the early Mito EVO Mikuni 35mm then you need a custom inlet from carb to airbox and likely a new airbox. Good luck finding those.
#3
Posted 14 December 2020 - 12:36 AM
By writing "bigger carb" I meant a carb that has a larger bore than the carb that is on the bike at the moment. I wish I didn't mention all of that other stuff. I understand carb adjustments. I should have just stated, "What is the specific change to be made to the snorkels inside a mito with an airbox restricted by those snorkels?" You're response says the "specific changes in the airbox" is "well documented". Please provide me a document/s that lists that specific airbox change. Just what to do with the restricting snorkels. That is really all I'm looking for. I've spent a legit amount of timing trying to find more about it but I've had no luck. Thank you very much.
This post has been edited by Fred Gwynne: 14 December 2020 - 12:40 AM
#4
Posted 14 December 2020 - 02:23 AM
#5
Posted 14 December 2020 - 11:28 AM
I recently restored a MK2, which has got me the Mito bug.
I am currently restoring a 2000 Evo, 11,000 miles. It goes ok and would do about 85mph on the flat, but did feel a little strangled compared to the MK2 which had its engine rebuilt by Acme Motorcycles (legends).
I have checked the compression which was 60psi so obviously this is a major part of problem and the bike will get a new top end. I was expecting close to 150psi if it was in good condition.
When I took the airbox off, there was a home made metal plate that was almost completely blanking the inlet to the airbox. I have photo's but can't figure out how to post them here. It had closed off 95% of the inlet. I can only assume this was an effort to restrict the bike but can't for the life of me think why anyone would do this.
With the plate removed the whole inlet to the airbox is open, so clearly the engine is going to breath better now.
But the question is, would it still give full power and run better with a set of inlet "Bunny ears" fitted?
Anyone able to help? I am happy to email photos of the airbox restrictors that were fitted or post them here if someone can help with advice on how to do that.
#6
Posted 14 December 2020 - 07:20 PM
:laugh: This is the most confusing single cylinder 2 stroke bike that I have ever looked into. Can we just stick a YZ250 motor in it and call it a day? Just kidding of course.
#7
Posted 15 December 2020 - 01:27 PM
#8
Posted 15 December 2020 - 09:15 PM
#10
Posted 17 December 2020 - 07:33 PM
