1 - 2 of 2 Posts
Hi!
Currently renovating my 125 in Sweden.
Where do I buy reeds? I have the 154cc polini cylinder and 34mm carb.
I am also looking for parts of anyone have?
Airfilter holder in the airbox.
Black caps over the engine mount
Front indicators
Brake lever
where does the fuse box mount?
Someone with a good pic over the electrical system over the battery and so on?
best regards Johnnie from sweden
125cc Sportsbikes Boffin
Think the reeds are the same as on the 123 engine, part number 224 430
Air filter holder should be the same as the Sintesi (airbox is VERY similar)
The black caps on the swinging arm pop up sometimes on Ebay. Might be good if someone can 3D print them
Front indicators are easily damaged. The indicator body is easy to find (Triumph used the same unit in the early 1990s), but the Triumph stalk is longer. I have seen 3D printed shorter stalks, or just use the long Triumph ones (or if your originals are OK, swap those onto the Triumph indicator bodies)
Brake lever is a common Brembo item used on loads of different bikes. They are easy to buy.
All the best
Katy
1 - 2 of 2 Posts
