ok starting this thread cos I need inspiration lol
seems aprilia ran out of money or just gave up on the air intake side of things
my own personal belief was they were at some point (late 90s) toying with the idea of a gp front mounted ram air pressurised box and just gave in
I currently run a open filter on my rs due to the port work larger intakes etc etc
now it runs like a sack of sh*t in the mid range and eats the reeds weekly I think this is due to turbulence and maybe the lack of a pressurized box
fact remains the bike pulls stronger and has more torqe everywere with an open filter although the noise is loud and can be annoying while at lights next to the local fuzz lol
so basically im looking into air box designs and priinciples trying to find the rite way to go
ive read that changing the lenth and width of the velocity stacks on the air box (rubber snorkels on a rs) can give mixed results apparently opening or replaceing these to the same size as the carb being used (34mm) does have its gains
taken from dyno testing a rgv with custom airbox
longer snorkels = gave less midrange more top end
shorter snorkels = short ones gave the same midrange but a little more top end and a little more on the over run
example of what I mean ..... this is a mc 21 nsr air box lid modified with custom stacks
and a rgv 250 airbox modified with custom stacks
what im thinking is takeing the rs air box or may be even something bigger (big enough to fill the void were the airbox sits ) and use a cold air feed off the 1996 ram air tubes ( or make a scoop ) in the front fairing to feed around the front of the trumpets of this box
from what i can make out its actually not about RAM AIR its about haveing still cold air around the trumpets and a SLOW steady flow in the box
forced induction of air into a pressureized box wont work (if my theory and a weekends worth of reading up on is correct lol)
the air inside the airbox will be turbulent and you're more likely to loose horsepower at high speed and wide open throttle with forced induction in to the box and will play ahvoc with the fuel pressure and temperature in the carbs with no pump
i beleive the way to go is to make an airduct from the from the front that gradually increases in cross sectional area, thereby SLOWING down the air as it get towards the airbox
as far as i can work out the bigger the size of the actual box the better
http://www.sportrider.com/tech/146_9910_ram/ nice read and results of ram air testing <<<
bought a few things to try and experiment with grabbed a cheap rotax max air box off flea bay dont even know if i can get it to fit in the void but for the price i just grabbed it lol
will defo be looking velocity stacks tuned lenth too
just posting all this for a discussion with the guys that have a bit of experiance with these matters
bounceing off each others ideas so to speak
suggestions comments welcome
