Will be a engine out and full strip down there is 2 balance bearings
You cut remove the inner bearing without splitting cases.it's a blind hole.You can remove the balance shaft and the outer bearing quite easy without splitting the engine, the inner bearing is a little more tricky but can be done![]()
Do you mean "you can't" rather than cut ?You cut remove the inner bearing without splitting cases.it's a blind hole.
To start off remove the the M5 screw that is holding the LH bearing in place, refit the C-clip on the balance shaft apply heat around the case where the bearing is and then pull on the balance shaft / c-clip with mole grips or big pliers and it should pull out with the bearing. Then you will need a internal bearing puller to pull the RH bearing out, that is the hard one to do.Would you be able to get a bearing puller in there? To make it easyer could heat the case up on other sidecwere bearing is.
Yes I meant can't.Think I'm going to have to look at a spare set of cases to familiarize myself.it's been a while.Very interested in extracting this bearing without splitting cases.I know you do this on a daily basis.good information Paul.Do you mean "you can't" rather than cut ?
You can remove the inner bearing, granted it is hard and most won't have the tool but it can be done. The outer bearing is only held in with a washer and a M5 countersunk screw.
They look completely different to me the one on the right even looks shorter guessing it must be wrongly listed or something just my 2 cents stick with one that looks the same as the one you haveI split the cases and i removed the bearings and the balance shaft ..The balance shaft is on very bad condition so i will buy a new one but i just noticed that there are two types of that shaft.Mine is as the first one..both of them are for rotax 122 engine..But why they are different ?Can i use the second one on my engine?
just had the inner/blind balance shaft bearing failed on my 122. I managed to get both bearings and shaft out without splitting cases, but it wasn't so easy. The clutch side bearing pulled out easy along with the shaft. for the inner one I adapted a blind bearing puller for long reach and heated the casing (near the flywheel). Once the bearing came out of its seat I then realised it wouldn't fit through the hole in the clutch side casing, so I had to file about 1mm off the lip around the clutch side casing to allow the inner bearing to pass through it, theres still plenty left for the outer bearing to seat against.
Hope this helps someone out to know View attachment 19291
