Cagiva Mito SP525 125cc model 2011, I accidentally loosened TPS-sensor screws while adjusting the carburetor. Well now it flashes the MIL fault code from the TPS sensor (1 long flash, 2 short flashes). The TPS sensor is properly put back in place (the black plastic pipe thingy moves when giving throttle), the screw is tightened in the same place (factory fortunately marked the right spot in yellow color) but odometer till flashes the fault code.
The current voltage from the TPS sensor has also been checked in accordance with the workshop manual, and nothing faulty with voltage. I also removed & loaded battery up but the fault code still remains.
Is there any TPS sensor reset instruction for Cagiva Mito SP525 that would turn that MIL light off? I also tried to dig from the Italian forums but could not find a solution to the problem.
