1 - 19 of 19 Posts
· 125cc Sportsbikes Supporter
sorry to thread-jack, but if i buy a ducati blank key from ebay (identical to the cagiva ones) will it be easy enough to get any old key cutter to cut it or do i need to take it to a specialist???
· Cagiva Geek :)
I cut mine at work, it has to be a cutter that cuts yale, union, assa type keys.
col
Hi !
does any1 happen to have original Mito Evo ignition key as a "left over/junk key" without its ignition switch/tank cap ?
i would need the grip-handle from the original key....
bye
markus
Hi !
bye
markus
i have an original spare key but thats mine for keeps
Hi !
bye
markus
Hi !
today i found out that its easy to pull of the grip from the original Cagiva ignition key. The grip has the Cagiva text and italian flag in it. it wasnt glued into place or anything like that, came of very easyly.
so this1 was just a tip to people who wanna get original look key (like i did), i purchased some original (scrap) keys from private cagiva parts seller and now i must only visit a locksmith and im back with original key look again
bye
markus
Just spoke to rob (Mito Mondo) he hasn't got any blanks, but he gave me the number of a place that will cut and post you out a key for £10.50 just tell them its a Ducati type key and give them the key/ barrel no. its not going to have Cagiva on it but it will work.
The number for them is
Keys Galore
020 7586 9741
there based in London.
hope that helps someone.
P.s. will let you know what it looks like when it turns up.
Cheers Si
probably they could but is it worth there time for a bike they'd struggle to sell for £600 with no docs?,
I still think there are descent people out there running honest businesses, if your that paranoid get a mate to order it on their card, delivered to their address then you aint got a problem, its still much quicker/easyier than ordering one of the fleebay Bulgaria specials and getting it cut.
also whats to stop someone looking at your bike and reading the barrel no. and then going to get a key cut? Bottom line never leave your bike secured with only the steering lock all it takes is a bored kid with a screw driver and its gone.
Si
Hi !
do those have "grip" that can be pulled of ? like the original..
bye
markus
ps. any1 remeber the time recently when some1 here at forum told about making new (sticker based) "face" for ignition barrel ? he said that he made it with a Computer program that was for making sticker based labels for CD's.
i dont have the stuff and i would like to have a new "label"/"face" for my worn out C12R ignition barrel..
Hi !
bye
markus
hi Markus
the grip can't be pulled off unfortunatly, the way which the metal is held in is different.
the key on the left is the new one, genuine cagiva key on the right.
which manufacturer makes the locks for cagiva? perhaps they will be able to supply the original spec keys
cheers
Si
Hi !
thx for the latest info with that photo, now i understand why the "grip" cannot be pulled of.
im going to use the ignition barrel serial number for making a new keys and then swopping the "grips".. Seems like the only hassle is to find a place that makes Ducati keys in Finland...
bye
markus
hi !
i ment a place that cuts ducati type keys...
my '98 ignition barrel has logo/text "AD" or "FD" but like once said serial number is all that is needed if not correct sample key to give...
bye
markus
1 - 19 of 19 Posts
