Zeeltronic is only option if you have a kokusan ignition (very small CDI)
I would not advise on the italkit PV. And I think you need to drill the cylinder for it. Not advisable while its on the engine.
You can lock the PV in either position by manually rotating the CTS controll motor. Hoe much you lose is best observed by you. It depends on pipe (exhaust) you have.
If you are deciding between zeeltronic and italkit and budget is a problem than by all means its Italkit. Or no valve is also an option.
For zeel you need to find out the reason for failure of CTS (PV) controller. As PV motor can draw a lot of power, a stuck valve in the cylinder will burn the CTS controller. Never bikes came with a fuse on it to protect the Controller from such high current.
If you have crazy good luck maybe only a transistor or diode has failed and might be worth giving it to an electronics specialist to try to repair it (if its cost beneficial)
