21 - 21 of 21 Posts
Ive had the bike for about a year now, not certain if any work has been done to the electrics. Previous owner never mentioned it electrics seem fine as everything electric works great.
I opened the clutch perch switch is visible as in it operates when pushed etc dont know how else to check it tbh? Although i have joined the two wires together off the side stand switch that never worked also i used a tester to tesy for any power in these 2 wires and theres no current in sidestand switch wires, dont know if thats the way it should be but sidestand works if in gear so i presume its ok???
Hi, did you manage to get it working. What was the cause? I am having the exact same issue. Thank you
21 - 21 of 21 Posts
