1 - 20 of 24 Posts
I found the side-stand switch the other day. I couldnt find it so I couldnt get the electrics to work. I stuck it on a few days ago and left it. I was on ebay about 30 mins ago and it was p**sing me off, so I thought, less p**s about with the electrics! I stuck a wire onto the generator and it was sparking like mad and the generator was running but no lights! I checked and I was like AHHHHHHHHH! I didnt have a full circuit, just battery to generator, not battery to the whole harness. Got that sorted:
HOHOHO!
I am amaze myself. I would have sex with myself if I was female.
I bought a CBR150 tail-light a while back but the connection does not fit the 125 connector. So, I stripped apart the 125 tail-light and plate light wires, the tiny indicator wires, bought Honda connectors and spent many many MANY! hours trying to re-wire this b*tch up and to create my own sub-harness for the tail-light. All the lights work but the indicators do not flash. I will need to replace the indicator relay.
http://i58.photobucket.com/albums/g277/lum...ds/DSCF2872.jpg
http://i58.photobucket.com/albums/g277/lum...ds/DSCF2878.jpg
http://i58.photobucket.com/albums/g277/lum...ds/DSCF2879.jpg
http://i58.photobucket.com/albums/g277/lum...ds/DSCF2881.jpg
http://i58.photobucket.com/albums/g277/lum...ds/DSCF2882.jpg
http://i58.photobucket.com/albums/g277/lum...ds/DSCF2886.jpg
http://i58.photobucket.com/albums/g277/lum...ds/DSCF2887.jpg
http://i58.photobucket.com/albums/g277/lum...ds/SP_A0556.jpg
http://i58.photobucket.com/albums/g277/lum...5Mods/wires.jpg
http://i58.photobucket.com/albums/g277/lum...s/wiringmod.jpg
http://i58.photobucket.com/albums/g277/lum...ds/SP_A0541.jpg
http://i58.photobucket.com/albums/g277/lum.../connectors.jpg
Honda connectors were bought from here:
http://www.electricalconnection.com/
· 125cc Sportsbikes Moderator
Could have told you before you bought it that the indis wouldnt flash, they dont on mine not botherd fixing it yet. Will need to tho by march for its M.o.t
You could of told me beforehand! why didnt you! lmao. Ive ordered an indicator relay ages ago though.
I cant get the key out of the fuel cap unless I stick it back on the fuel tank or squeeze the cap but Ill keep it on the key bundle for now.
Its easy tp get the key out just poke the tabs on the underside of the cap. I mangled my vfr one to get it out then when i did i noticed out to do it. I was like oh ant you dumb f*ck.
Got one of these myself a while ago and finnaly got it finished.
Used some capless 21w bulbs instead of the ones what came with the unit.
For a cheaparse fitting:
-Get bulbs from dashlights.co.uk (capless wedge 21w) for about ?3.
-Get some bullet connections and a crimp tool from friendly motorist shop, or if you can get honda connectors get them.
-Sand down 6pin block to 3 pin block, you can remove the crimps inside by pushing a small flathead down the top and pulling.
-Find a damaged indicator or one your not going to use and chop plug and 4cm's of wire, crimp bullets onto these and end of indicators.
-Check conntections with bike fittings.
-fit properly, then swear, remove and fit. test again. and smile smugly
You make it sound like a piece of p**s
how long did that take you? 5 mins?
I never thought about sanding down the 6 pin block!
Take some pictures of the connections!
I tried LEDs for the indicators and they worked. I cant find the ones you mentioned. 21w? not 2.1w? Did you replace the brake light bulbs?
10 minutes once i worked out what i needed.
the bulbs are these: http://dashlights.co.uk/cart.php?target=pr...roduct_id=16329
You'll need to trim about 1 milimetre off the twisty locking thingy on the tail light as bulbs are bigger.
Definetly 21w as it will match the oem indicators from Honda, my guess is that its a very small range of ampage what the relay handles.
Didn't need to change brake lights as they seemed pretty bright.
heres some pictures of my bodge jobbing
love to see u come on site in a weeks time sayin oh f*ck ive blown all elcs
The way I did my rear indicators was with a simple chocolate block. Cut the old connector off, terminate into block, cut new indicator wires off terminate into block. Reconnect the honda connector. Works a charm! Theres plenty of room behind the tail light to fit em n all.
(Didnt work on the front ones, after I cut the wires I realised there was nowhere to put the damn block = no front indicators for a while)
1 - 20 of 24 Posts
