I know that fireblade cans fit on the srad and visa versa, not sure about the zx6r though, i wouldve guessed they would....See the 3 bolt on ones, e.g. fireblade, srad, zx6r end cans, are they all the same fittings?
are they interchangable between themselves?
thats quite abit, you might get away with using a file on the holes until it fits, or drill them out an extra 1.25mm.Emailed a guy on ebay selling an akrapovic, he measured distance as 95mm from centre to centre of 2 holes, and on my zx6r can its 90mm, not sure how much of a problem that 5mm will cause![]()
fireblade,srad cans won't fit,i know that zrx11 cans will fit zx6r g's and j's though,if the can has a strap it will fit fine but if it has a bracket it will need to be moddedSee the 3 bolt on ones, e.g. fireblade, srad, zx6r end cans, are they all the same fittings?
where abouts on the holes did he measure from though?? was it from the centre of each hole or from the edge of each hole as that may be where that extra 5mm is coming into play if you measured from the edge of the bolts holes and he measured from the centre of them lolEmailed a guy on ebay selling an akrapovic, he measured distance as 95mm from centre to centre of 2 holes, and on my zx6r can its 90mm, not sure how much of a problem that 5mm will cause![]()
measured from the centres ofcourse lol, but dougs had one of these so I guess hes right, Has to be a carbon akra, not having any other can.where abouts on the holes did he measure from though?? was it from the centre of each hole or from the edge of each hole as that may be where that extra 5mm is coming into play if you measured from the edge of the bolts holes and he measured from the centre of them lol
jimbozr7 has one for sale if im not mistaked, carbon bolt on akky, looks and sounds lush.measured from the centres ofcourse lol, but dougs had one of these so I guess hes right, Has to be a carbon akra, not having any other can.
Fathead......lives down our way, he had an ad up for his carbon akky...eh? nah dougon2wheels had a red 6r like mine. Im in london, and whos this jimbozr7 fella?
Well, what effects will a new can have on performance, if any? Or is it just sound?well you can get quite alot of cans for a bandit mate?? upto you, you can get a viper and i can sort you out one cheap mate?
you can get akrapovics, micron etc i think
macey
