1 - 20 of 61 Posts
do not even contemplate trying this unless you have a basic knowledge of mechanics if your not confident leave it to a professional
this is by no means the official or correct way to do things, just the way i do it.
engine removal
tools needed to do this
swingarm pivot lock nut key
10 mm spanner / socket
8mm spanner / socket
13 mm spanner / socket
17 mm spanner / socket
22 mm spanner / socket
m6 allen fitting
m8 allen fitting
small flat head screw driver
phillips screw driver
long nose pliers
trolley jack
piece of wood
plastic or rubber mallet
rite first off remove the side fairings,oil pump, carb and top cylinder engine mount if you cant do that you have wrong bike for you
once thats done ^
remove the gear oil plug and drop the oil
also remove the gear linkage from the shaft
then remove the top off the coolent bottle and find the coolent drain bolt and remove and drop the coolent
also disconnect this tube from the rad and drain the rad
then disconnect the temp sensor and remove the spark plug cap
then unplug these wires pictured
and the netruel sensor by the front sprocket
remove the batt and batt tray
remove the hose on the cylinder head water jacket cover
remove the rave valve
remove exhaust springs
remove mid exhaust mount bolt
and the rear exhaust mount bolt
remove exhaust
remove front sprocket circlip
and remove front sprocket
remove the clutch cable from the lever end
then from the engine end
remove the earths from the mounting point and put the bolt back in as not too lose it
remove the starter motor live lead
remove the swingarm lock nut and loosen the pivot bolt off (note special key needed to remove the lock nut or a screwy and hammer )
then remove the lower engine mount bolt
at this point support the engine using a trolley jack and a block of wood from the bottom if your feeling brave theres no need too
remove the front engine mount
then loosen and withdraw the swingarm pivot shaft just far enough to clear the crank cases no further do not fully withdraw it
then lower the engine down on the jack may need a few taps with a mallet here and there to get it free
once lowerd push the swingarm pivot shaft back threw and tighten it up
engines out
mounts
removing the cylinder head and cylinder
tools you need for this
this can be done with the engine still in the frame but i find it easier out of the frame
11 mm spanner or socket with bend
13 mm spanner or socket
14mm spark plug spanner
m6 allen key attachment
first off remove the spark plug
then loosen and remove the 4 allen key bolts securing the cylinder head water jacket cover
and remove the cover
then loosen off and remove the 13 mm head bolts securing the cylinder head to the cylinder
and remove the cylinder head
once the above is completed you need to find the 4 cylinder base nuts and loosen and remove these with the 11mm spanner
then tap the cylinder lightly on the four corners of it to release it slightly
then with one hand under the reedblock side and one hand on the exhuast mounting stub pull and rock gently back an fourth, the cylinder will gradually release itself from the piston
so your left with this
top write up steve, I'm going to go have a go at the "special" tool nut then with a hammer and a screwdriver, didn't think of that, I need to drop the engine.
if you go down the hammer and screwy route prepare too fork out 5 £ or so for a new lock nut if its on real tight
the tool only a 10r and tbh its a must have owning one of these as my engines out more then in lol
http://www.ebay.co.uk/itm/APRILIA-RS125-ENGINE-SWINGARM-LOCKNUT-TOOL-RS-125-aa-/300590016591?pt=UK_Motorcycle_Parts&hash=item45fc8fa84f
lol
Bargain! Never thought of looking on ebay! Thought with it being italian special tooling they'd have you paying through the nose, Ordered!
cant you do the piston and rings with the engine in on the rs then? also, is the front sprocket only held in by a circlips??
This came at a really helpful time for me cheers pego. Also thought its worth mentioning, I did the whole 'modify a socket instead of forking out and buying a swingarm locknut tool' trick today. worked a treat. Fits perfectly now and I saved 15 quid
You need a 22 mm socket, a vice, hacksaw, ruler and a set of files.
Prongs should be 5mm deep, 4mm wide and then about 3mm from the edge towards the centre. Hope you can see how I mean :p confusing I know
Thought using a grinder would be too inaccurate and powerful as the work is quite intricate.
Thanks to G30 for the idea!
Great write up as usual pego! Also ... get rid of them chicken strips ^^ its an RS how can you fail to reach the edge of the tyre :D :D
top rite up pego and piccys...cant wait too see results of flat top with the abbey cylinder you going to run with the two base gaskets
good write up Pego
, things like these help people stop posting the same things on the forum over and over again
http://www.ebay.co.u...=item3cbafb70e3
good guide mate.
yes tswing-armarm nremovalvel tool is a must.
but beware if you use it harshly it will break as they are only stainless steel.
They are a top tool to have if you are following this post.
1 - 20 of 61 Posts
