21 - 40 of 61 Posts
splitting the cases for inspection purposes only
tools needed
17mm spanner
m8 allen key attachment
m6 allen key attachment
plastic or rubber mallet
small thin flat head screw driver
first off remove the engine front mounts from its lower mounting position on the cases
then loosen off and remove the 9 clutch case bolts
and gently lift off the clutch case
take note of the 2 spacer / washers on the gear selection rod / shaft dont lose them
now gently lift off the clutch basket
remove the gear selector mechanism
now remove the oil pump drive gear
then remove the circlip on the balance shaft primary drive gear
and lift the gear off off the shaft end
now remove the circlip off the crank shaft primary drive gears and remove the gears
loosen and remove the gear drum stop mechanism
and remove all the crank case bolts
once all the bolts are removed place the engine sat up as it would in the bike
now tap the shafts with a non metal hammer (rubber or plastic) only tap do not damage the shaft ends
the cases will begin to pry apart
at this point place the engine back on it side clutch case side upwards and gently lift off the 1 half of the crank case
note the spacer / thrust washer on the output shaft dont lose it
cases are split you can now inspect the innerds for wear or damage
steve you should make some kind of book and just sell it on here lol, you would make loads
I managed to get my engine out without the need of using a special tool on the swingarm , just undid did the bolt on the left and jobs a good un
Discussion Starter · #33 ·
getting it back in might be a problem then as the swingarm pivot bolt adjusts the position of the swingarm and is handy to loosen it off so all the other mounts have more space to line up on reasemble
tighting the pivot pushes the swingarm loosening it pulls it
if its not done properly youll end up with the rear wheel out of allighnment with the front (which is a mot fail)
Thanks for the great guide pego came to very good use!!
Cheers Jak
pego any chance i could have a link to your photobucket please? can't see any pics and would like them if i'm doing this bottom end tomorrow lol
that e- clip assortment box in the piston photo must come in handy the amount of e-clips iv lost from my carb needle grrrrrrrrrrr
Jak
21 - 40 of 61 Posts
