[quote name='Bananas' date='Mar 14 2007, 02:36 PM' post='556752']
Second you've got the flywheel off, wrap the end of the shaft where the woodruff key is with a little electrical tape. Saves you from losing the key and will protect the end of the shaft from getting dinked accidently by anything!
Whoah your betsy there kiddo. Before you start going mad with the spanners, hang fire.
Firstly - What model and year of Mito do you have.
Secondly - Exactly what work did the garage do for you.
Thirdly - Exactly what was the fault that made you take the bike to the garage in the first place.
Not being a pedant here, but you need to tell us the whole sordid history of what's happened so we can start at the beginning and look logically at the problem to try and resolve it.
Sounds to me that you may have more than 1 fault, and if you go diving in without taking stock of what is going on you'll end up getting into such a mess and creating more problems for yourself. Not trying to tell you how to suck eggs, its just you need to step back and take stock of the problem before ripping the thing apart!
its an evo on a (R reg)i took it to the garage as they said the piston need changin so i had a topend kit fitted.then they rang me up sayin that its not sparking even tho the bike was running when i took it to the garage and i needed a new cdi and that would be another 400 quid.so i got my self 1 from mito mondo with a new ht coil and new plug and still no spark
