1 - 20 of 165 Posts
· CBR125 Section SuperMod!
honestly dont know mate ill try find out
wudnt imagine so aint that heavy. just whack it in a jiffy bag and send it standard, not like its gonna get damaged.
P.s. Karl, i think u shud warn them about the gut wrenching powerslides and uncontrollable wheelies in every gear.
indeed i should i spose
Dont need a sprocket, but if u have a spare 30mm+ carb to fit a a CBR lying around, ill take one of those.
got a 32mm carb in garage if you interested paul
yer but i have no idea if its the right type or not, like will throttle and choke connect up properly for a start.
if you could have a look compared to carb on CBR wud be great, speak to u on msn about it
always thought smaller front sprocket = better accel and less top end ?? it cant equal both ???
it can on the CBR, as 6th on stock gearing is basically an overdrive, it wont pull in 6th it just cruises. lower gearing makes 6th a usable gear, allowing the engine to rev to the redline in 6th therefore going faster.
The 06 CBR's dont come geared down do they? As I've always found that my 6th will pull and just before redline hits about 90 down a hill still pulls pretty well on the flat just often need to shift into 5th to keep revs up when i hit an uphill!
ummm no pretty sure they dont, there are lots of variables though, tyre pressure etc. will make a very small difference
everyone i know that has down geared has been really chuffed
down geared you wont have to go back to 5th on flat it will pull in 6th
1 - 20 of 165 Posts
