1 - 12 of 12 Posts
Quick question does the lil CRB have a electric or manual fuel pump? The reason I ask this is because after doing some stuff to my old bike yesterday she wont start today, I believe fuel is not getting to the carburetor. So I want to look into it.
Thank You
I'd imagine it would be electrical/mechanical as if it was manual you would be forever pumping whilst you were riding.
If all the lines are connected correctly then try turning it over (with the choke on) a few times to draw fuel into the carb
· CBR125 Section SuperMod!
its a vacuum pump... if you get the hose that connects to the inlet manifold (not the carb) then suck it, fuel will go down the other line and into the carb, then open the overflow screw if fuel p**ses out you have fuel getting to the carb
just reach under frame and pull it off no panels need removing
your right, if you look on the silver dome thing on the bottom of the fuel tank, two pipes you want the one on the bottom
little screw on the bottom of the carb near the overflow pipe
1 - 12 of 12 Posts
