Hello,
I've recently bought a Rg125F from about 1993 or 1994. I have a few problems and questions and i believe this is the place to ask.
1. So i wanted to change the handle bar endingd however when i tried to screw out the one on the left side, the screw just kept spinning which means the thing that is inside the handlebar is loose ?? How am i supposed to get it out then
2. I also tried taking off the thing behind the rear seat where the passanger is supposed to hold on to but i just couldnt get the screws moving i just damaged them. I also tried spraying wd40 onto it from the inside but it was still impossible. Any ideas ?
3. How do I remove the main seat ? Is it only that one single screw that goes through it ?
I would really appreciate any help!
