1 - 20 of 23 Posts
Mine to, more agressive sound in high revs!
But I like to blaim the Iridium for what happend to my bike..
the cause of your prob was badly set up motor , yer can see all the pinking marks on the piston
so yer timinig was to far advanced or squish not properly set this with slightly lean mixture will cause this kind of prob
· Wheelies on peds with no gear = win
My RS seized on an iridium plug. Not had a problem since going back, although did sound really nice.
It had been driven with the same set up for 8000km`s, then I switched to Iridium and got funny noises on the first ride..
20km`s later this happend.
the funny noise yer could hear was pinking . sounds like wrong grade of plug if that was only change
with plugs with very small tips its critical to get the correct heat range or the tip over heats n yer get pre ignition as the pic of the piston witrh the pock marks n bit missin shows
same result if the squish is not set correct to !!!!!
br9es and br10es are enough for mito engine
Hi !
Dear Stephen, you better swap away the B9ES/Br9ES. it's totally sh*t because it's std, thats why it has "S" in it. its like moped Sparg plug for 2horsepower
use B95EGV or B9EG or B9EV and you will notice difference in performance and durability, defenitely.
bye
markus
· Does not know Everything !
Ive used a wide selection of different standard plugs, heat range and palladium plugs for the mito - the palladium plugs give a crisper throttle response.
1 - 20 of 23 Posts
