look at the tank tap . very often the filter is blocking petrol . undo the carb , control the water in it's tank (bad petrol do that) , check the fuel valve and the fuel in the carb's tank . take the choke off ,under the piston look if the kind of rubber (round) is ok otherwise order the choke system at eurocarbs.co.uk and any other part . carb is 28PHBH/FS . now look the sparks of the plug . lift the tank and let it on the stand . undo the plug , put it on the cap and let it lying on the cylinder head . key on and press start button while watching . if you've got blue sparks it's perfect , otherwise you may have a worn stator . also check contacts everywhere with the black/yellow wire . it come from the CDI then goes to the coil and to the tachometer . very often if you see your tacho unstable it's loose contact . good luck
