I have a problem with my lexmoto hawk,
Every time I reach a certain distance my engine cuts out and won’t start again for 5-10 mins
I’ve changed a lot since this has started to try an find the issue but nothing so far has worked it’s had :
A new spark plug
Fuel injector
Fuel pump
Ecu
Rectifier
Lambda sensor
Temperature sensor
Throttle body
Air box
Fuses
Oil
Valves adjusted
I’m now stumped without having the rip the engine out an taking it apart any suggestions
A new spark plug
Fuel injector
Fuel pump
Ecu
Rectifier
Lambda sensor
Temperature sensor
Throttle body
Air box
Fuses
Oil
Valves adjusted
