1 - 3 of 3 Posts
Can any one help what loom I’ll need for a 2007 Aprilla 2T I had a loom on but kept blowing a fuse, without ignition on, so I’ve taken it off but seems like I was running an old separate power valve box and ECU, but I also had the new clocks, apparently I cannot run the old loom with new clocks, could someone help me in tell me what euro loom I need and box for the powervavle and ecu built in??
Pictures of what you had might help with identification. As to CDI (ECU) , PW unit etc..
Well I’m just scraping the old loom because it’s a make shift, so it has a 2002 power valve, with a separate ecu, which the 2007s have the powervavle and ecu built in together
1 - 3 of 3 Posts
