1 - 3 of 3 Posts
What are the carby and inlet manifold options for a Mito ?
38-41 mm sounds huge and the manifold area might be difficult ?
I read somewhere you can grind enlarge the mito manifold to fot a bigger Delorto?
I have a 32 PHF Del'orto ex ducati i could put on , with accelerator pump, do you disable the pump?
What round slide del'ortos fit?
Line from oil pump to carby?
Ducati Cas.
Carbs for the mito / supercity -
Mikuni TMX35
Dell'orto PHBH 28
Dell'orto VHSB 34
The 35&34 *can* fit into the 28 manifold, but it's tight and might split old rubbers.
I wouldn't mess around with fitting a 4T carb to an 2T, unless the accelerator pump system can be easily bypassed.
If you're running a phbh, the vhsb / tmx is a good upgrade, but requires some setup time to make the most of it. See my VHSB34 thread for my findings.
Oil feeds - some RS owners talk about fitting new oil feeds to larger (38) carbs, but i've never seen it work.
Ducati Cas.
Hi !
if ya wanna know the Cagiva OEM manifold options do a search, look for my writings because i have written about the stuff..
ps. there aint any aftermarket manifolds available if your wondering it..only OEM manifolds are/were produced like ever.
bye
markus
1 - 3 of 3 Posts
