Hi all,
I'm having problems with my rear brake light and clocks, the brake light works fine from pulling the levers as in when it goes brighter but the initial rear light itself does not work!
The bulbs are fine, the earths are fine, the fuses are fine.
At the same time this happened, all the lights in the clocks stopped working(the ones that come on when the lights are on so you can see the dials).
I have followed the wiring back to the front, everything is connected up.
Their is a yellow wire on its own with a clear sleeve over the connection, this wire looks suspicious to me, but upon trying to test it for current theirs no power flowing through it but if you put it to earth the rev counter jitters?
Any ideas?
Jonny
Any ideas?
Jonny
