Hi, hoping to get a few pointers, I’ve bought a FP 2008 RS and stripped it to bits the day after buying it.
What does the vacuum pressure switch do and do I need it? Mine was hanging loose and I’m pretty sure the vac pipe from the carb and the little filter pipe were on the wrong way round.
I gather it should be attached to a bracket with the SAI bits, is it part of the same system? Mine has no SAI system on it so presume it’s been deleted?
There is a little white clip with a zip tie through it down near the front sprocket, riveted onto the frame. What is it supposed to hold?
There is a brass union fitting on the RH crank case, above the stator cover. Mine has nothing attached to it. Should it have a breather pipe or something on it?
Ryan
Ryan
