1 - 13 of 13 Posts
hi my mito has been sitting for about 3 mounths will i worked on it, just got it to the stage where was ready to fire it up and nothing, zip, bugger all.I then bought a new battery thinking it could be that slapped it on and still noting, no lights, horn it doesnt even turn over, i have checked the earths and all seem fine and still nothing.I have not touched any electrics as i was only repainting the faring so i have no idea whats wrong!
Any ideas or suggestions would be great, as its doin my head in at tho moment
hiya the only thing i can recommend is to go through it bit by bit check the fuses maybe some corosion in a plug pull them appart check them/clean them up. good luck with it must be quite simple if everything has gone.
Thanks lads i have checked most connection blocks and all fuses and nothing not checked the ignition switch yet, does any one know if its a sealed unit or not?
It'll be a wire coming from the ignition. Or you're silly and haven't put the connections back on the battery. Have a search and there's a decent wiring diagram that was posted the other week. Pretty colours and all that.
Did it sit inside or outside in the elements?
Mark
Just a thought, before you start attacking the wiring, the new battery is definately ok and fully charged isn't it?
I know its probably fine, but how you'd feel like this
if you discovered later that the it was just the new one was duff!
Discussion Starter · #12 ·
Thanks everyone for your help its finally fired into life, a pin in one of my multi pin connector on wiring loom had corroded away and snapped off.Stuck a pin in it for now will replace it when its not dark and sodding cold.
thanks again lads.
thanks again lads.
Nice one!
1 - 13 of 13 Posts
