I just keep mine under 5-6000rpm till the temp shows about 55 - usually only takes a few mins4/5 mins is too long iirc think 2mins is enough as long as u can blip the throttle without it bogging down then ride it below 6000rpm till engine reaches temp ( 60c ) then ride it how u like, think thats right but im sure OP will put me right![]()
Hi !I just keep mine under 5-6000rpm till the temp shows about 55 - usually only takes a few mins![]()
Surely the temp shown is the coolant / radiator temp??Hi !
id say that because the Temp sensor is located in Cylinder Head you still have very cold coolant in radiator after temp show's 50~60.
Its typical f*ck up to rev the engine highly after the temp get's 50~60 as the whole system aint in that temp.. when you start to spank the engine like that it get's very cold coolant from the radiator and that aint good, so better warm up the complite coolant system enough before high rev's and fast riding !
bye![]()
markus
Hi !Surely the temp shown is the coolant / radiator temp??
I would be very surprised if a cylinder head only ever got to 60???![]()
When stationary there's no airflow cross the rad to cool it, so temperatures will rise quite quickly. Once you're moving again the air flow across it will quickly drop it again. Saying that tho, if deffo sounds like your thermostat is stuck open for it to happen at all!When i was on my way home from work today, When i was waiting at the traffic lights the temperature gauge was at 50but whn i rode off it went back down to 40![]()
westie
Hi !Thermostat opens at 65 degress C. ...
