1 - 13 of 13 Posts
· Sargent Sarcastic
Try this
Carbs/Fuel Injection
1. How to Richen or Lean your fuel map without a Power Comander (03+)
http://r6messagenet.com/forums/showthread.php?t=15407
2. Carb Removal
http://www.eecs.tufts.edu/~sbruno/carbfaq/
3. Factory CV Carb Tuning
http://www.factorypro.com/tech/carbtun.html
4. Velocity Stack Install
http://r6messagenet.com/forums/showthread.php?t=18025
5. AIS Block off (how to stop decel popping)
http://r6messagenet.com/forums/showthread.php?t=14454
6. Ivan\\\\\\\'s Jet Kit Install
http://r6messagenet.com/forums/showthread.php?t=529
Sprockets/Gearing
1. Gearing Calculator
http://www.yzfr6.net/sprocket_speed.php
Aesthetics
1. Decal Removal
http://sportbikeguy.com/garage/floor/decalrm.html
2. Plastic Repair
http://sportbikeguy.com/garage/floor/plasticrepair.html
3. Plastic Painting
http://sportbikeguy.com/garage/floor/painting.html
4. Rim Polishing
http://sportbikeguy.com/garage/floor/rimstrip.html
5. 99-01 Tail Conversion
http://www.drexelmgt.com/Lee/tail/
6. Polishing
http://r6messagenet.com/forums/showthread.php?t=14031
7. Wash Your Bike
http://r6messagenet.com/forums/showthread.php?t=14973
Electrical
1. Rear Turn signal brake light integration
http://sportbikeguy.com/garage/floor/signal.html
2. Running lights in Headlight corners
http://sportbikeguy.com/garage/floor/headlight-mod.html
3. Installing Black Robotics\\\\\\\' Yellow Box
http://www.biketweakers.com//r6_yellowbox.html
4. Speedohealer V2 install
http://r6messagenet.com/forums/showthread.php?t=18722
Engine
1. Valve Clearance Check & Adjustment
http://r6messagenet.com/forums/showthread.php?t=14272
2. OEM CCT Replacement
http://r6messagenet.com/forums/showthread.php?t=16606
3. Change your oil
http://www.angelfire.com/ia/z/R6oilchange.htm
4. Install Full Exhaust
http://r6messagenet.com/forums/showthread.php?t=13972
Suspension
1. Suspension guide 1
http://www.yzfr6.net/images/Suspension_Guide1.jpg
2.Suspension guide 2
http://www.yzfr6.net/images/Suspension_Guide2.jpg
Brakes
1. Brake Line Removal, Install, and Bleeding
http://sportbikeguy.com/garage/floor/brakeline.html
Misc Removal/Adjustments
1. Dentent Spring 99-02
http://r6messagenet.com/forums/showthread.php?t=17148
2. Frame Slider install
http://sportbikeguy.com/garage/floor/frameslider.html
3. Tire Mounting / Balancing
http://www.clarity.net/~adam/tire-changing.html
4. Installing NRC Engine Case Covers
http://www.biketweakers.com//r6_sidecovers.html
5. Front Wheel Removal
Other
1. Rear Stand Dimensions
http://www.geocities.com/dsmperformance/R6.htm
2. Homemade Camera Tank Mount
http://r6messagenet.com/forums/showthread.php?t=14993
3. 30 Exhaust Sound Clips
http://www.sportrider.com/tech/146_0410_pipe_clips/
HTH Russ
1 - 13 of 13 Posts
