1 - 8 of 8 Posts
he is correct if your useing the right side socket then you wont round off the edges but you can sher the head off the bolt very easly
What would be the use of using a Torque wrench over tighten & shear a bolt, the idea is to set the torque wrench to the correct torque setting for the bolt, so that you do not over tighten a bolt & damage it.
Chris.
on the Torque Wrench front.
Only problem is that they're expensive
1 - 8 of 8 Posts
