After searching the internet,i could not find any information on bearing and oil seal sizes to rebuild my shock linkage.
So i decided to strip it,measure all the components and order the parts from various suppliers rather than paying for genuine Aprilia parts.
So here is a detailed list:When it comes to rebuilding your linkage,you can choose the parts you require to rebuild yours.
As i stripped mine down,i found all the seals and only one bearing needed replacing but i decided to overhaul the complete unit.
There are 5 bolts on the shock linkage - i used stainless steel allen cap bolts,nyloc nuts and washers.All of which can be purchased from www.boltmeup.com very cheap and very quick delivery.
M12 X 85
M10 X 125 (need to purchase m10 x 130 and shorten the thread)
M10 X 80
M10 X 75
M8 X 50
1 X M12 NYLOC NUT
3 X M10 NYLOC NUT
1 X M8 NYLOC NUT
2 X M12 WASHER
6 X M10 WASHER
2 X M8 WASHER
Next is the sleeves/spacers that the bolts pass through.There are 4 of these which cost a fortune from Aprilia.You can get these machined from mild steel then case hardened.Spacer sizes AFTER case hardening are as follows.
LENGTH O.D I.D
24MM 18MM 8MM
74MM 18MM 10MM
49.85MM 18MM 10MM
49.85MM 18MM 12MM
Next are the oil seals.There are 6 seals in total and there all the same size.
24mm O.D x 18mm I.D x 3mm Width
www.simplybearings.co.uk ÂŁ1.89 each + vat & pp
www.apriliagenuineparts.co.uk part number AP8110068 ÂŁ46.32 for 8 x oil seals..EEEEEEEEEEK
Last of all the bearings.There are 3 bearings in the standard rocker.
1 off hk1812 - 24mm O.D X 18mm I.D x 12mm Width
2 off hk1816 - 24mm O.D x 18mm I.D X 16mm Width ( plus another 2 to convert to a 5 bearing rocker )
There is room to make this a 5 bearing rocker which will make it more stable buy fitting another 2 hk1816 along side the standard bearings.It's totally upto the individual wether to do this.
www.simplybearings.co.uk budget roller needle bearings start at ÂŁ2.56 plus vat & pp
www.apriliagenuineparts.co.uk torrington roller needle bearings ÂŁ12.00 plus vat & pp
Here is a photo of my finished rocker: INA oil seals,torrington bearings,New stainless bolts,nuts,washers,used the oem spacers.Cost me around ÂŁ30 all in.
Wondered if this information/thread should be stickied??????
M12 X 85
M10 X 80
M10 X 75
M8 X 50
1 X M12 NYLOC NUT
3 X M10 NYLOC NUT
1 X M8 NYLOC NUT
2 X M12 WASHER
6 X M10 WASHER
2 X M8 WASHER
LENGTH O.D I.D
24MM 18MM 8MM
74MM 18MM 10MM
49.85MM 18MM 10MM
49.85MM 18MM 12MM
