1 - 4 of 4 Posts
take off exhaust pipe and look inside the exhaust port how much carbon inside especially on the valves flaps . if you find much , it's time to decarbonize and change piston-kit .
if ok i suggest good cleaning on :
- tank and tap (fuel filter)
- air box foam filter
- carb (strainer and float chamber) and blow all the jets
- gear box oil change
- oiling on every cable
- break pads check
You reading my mind Alain?
Got the exhaust off at the min to change it for a derestricted one. Looks fine.
Also just changed the jets and cleaned the carb out while i had it off.
Think i need new brake pads though?
1 - 4 of 4 Posts
