2 questions about the standard exhaust:
1. does your end can have a hole on the underside, as in a machined hole that should either be there or have a stud in it, near where the st steel end can section bolts onto the black section.
2. Has anyone heard of a tweak you can do by removing the end can, or maybe somewhere closer to the engine and opening a valve? You loosen a screw, hold the valve open, retighten the screw.. valve stays open or something? Someone who has an 05 mentioned this one to me the other day
