1 - 1 of 1 Posts
so from last time, i needed a new loom, I've brought one, but had some weird experiences with this new one at first when it was all apart and adding the loom i connected everything then i didn't get a spark, this was with no air box, so i took a look with the magneto, it had a massive gap so i pulled it closer, then i bumped it because my battery was dead and it fired up so i put it all back together and then i have no spark coming to ride it, I've charged the battery reading 12.5 v, I've checked coil with a multi meter seems good, I've checked pick up wire from engine seems fine got all the correct readings, checked the wire from cdi to sparking coil, its not got a break in the wire, I've checked the kill switch I'm only left with cdi? any help with grounds or another idea would be massively apricated any one know how to test a 2007 cdi box for Aprilia rs 125? thank you!!
1 - 1 of 1 Posts
