what is your top speed on tacho and on flat surface ?
we need to compare all the settings :
the final ratio (for example 14x41)
the cylinder number (for example a0401)
the cylinderhead (for example 200 h)
the piston (1 ring or 2 rings flat or dome wiseco)
the carb u used (35 or 28 or others)
the gearbox (6 or 7 speeds)
your own weight
i start : 172 km/h tacho
200 dome mito 1 black cylinderhead
60433 cylinder of mito 1 (1990)
1 ring piston vertex flat instead of the classical 2 rings dome piston
14 x43 and 7 speed gearbox of mito 1
28 rd carb
my weight was 90 kg
let's go guies....and do not joke with the speed ....
your own weight
28 rd carb
my weight was 90 kg
