1 - 13 of 13 Posts
i emailed a company near me, drayton croft to see how much a major service would be and what was included and heres there reply:
Valve clearance
Air Suction Valve Check
Air Cleaner Clean
Throttle Play
Idlespeed Checks
Carb Balance
Evaporation Emission Control Check
Oil and Filter change
Drive Chain Check
Brake Check
Brake Light switches check
Steering Check
Rear Shock leak check
Tyre inspection
Brake fluid change
Clutch adjust check
Coolant change
the cost will be ?330.00
additional charges are as follows:-
?5 per shim if replacement needed
?50 fork oil change
?50 Swing arm strip and regrease
mint price mate
400 just fot the general check n valve clearance round here n i think its 12 pound a shim
do it
· Premium Member
Valve clearance
Air Cleaner Clean
Throttle Play
Idlespeed Checks
Carb Balance
Drive Chain Check
Brake Check
Steering Check
Tyre inspection
Brake fluid change
Clutch adjust check
Coolant change
?50 fork oil change
thats f**king crap. half the list is glancing at the item and not even checking it, looks like a mid range stage 1-2 service.
its crap, get a full stage 3 service for like ?350 and that includes fork oil/seals and valves
how do you know it will be 360 from where he lives????????
I would say it's that bad as long as that includes all the spark plugs, oil, filter etc. Alot of that list is just general visual checks, so is done when they're doing other things....on the off chance they can charge you more
Valves is the costly bit, it's a good 3hrs just get strip and check, plus a few more if they need adjusting/changing. Although the Brake fluid and coolant change ins makes it a pretty good deal as long as it includes VAT
That would mostly be a all-dayer.
i would never go planet bikes they are c*nts!! had loadsa trouble with them before, i cant think of anywhere else to get it done i thought drayton croft would be a good decent place as i seen them at mallory and thought they would be quite reasonable and do the job properly, i reckon they are all bout the same price for the same sorta thing unless i look at taking it elsewhere a bit further out if its a better price and a better deal but i wouldnt know of any other places!
you find me a place tht will do it for tht price then mate in leicestershire
exactly.
could yo find me one round here aswell please sounds a hell of alot better than 500 which is what it would be for that kind of service
im dreading my 15000 mile service
exactly.
Easy, do the oil/filter/plugs etc etc yourself and get them to check the valves, chances are they wont need adjusting so will be around 3hours labour. I'm taking the plunge and checking my own valves from now on, in theory it seems easy enough and the more I read up the more it makes sense.
· Premium Member
seems a tad steep in all fairness ... and you can generally tell by the sound of things when you're valve clearances need doing, and if you use your bike alot, you tend to notice when it goes a bit flat for a carb rebalance ...
had a Honda WSB mechanic do my 15k service, was top notch
· 125cc Sportsbikes Moderator
valves arnt thatttttt hard did them with my dad on his FJ1200 (didnt need anythink changing mind) you'll need a valve lifter as well if you do them yourself.
Im looking at putting some raceing valve springs onto the zxr when i next ajust them, idea is do as much as i can on the engine that i dont mind blowing up to gain experiance so far though its running better than ever
good point mate but id rather pay the money and have it done properly as 1. i dont trust myself and 2. if it all goes bang etc 2 weeks down the line i can sue
1 - 13 of 13 Posts
