Mito Gearbox oil
1 reading
33K views 59 replies 25 participants last post by  newmito
#1 ·
ASAP thanks, sorry but my manual is sh*t.
#9 ·
NOOB question alert!!!!
im checking the oil level.... now should it be to the ridge that is about a cm up from the end????
checking the manual it simply says check the level and top up if necessary.... doesnt state up to the ridge/mark or what ever...
so im asking.... i need to put some in as it appear the stick is bone dry!!!!! :-(
thanks guys!
#10 · (Edited by Moderator)
summin to add into this talk FOR noobyes !!
automotive motor oils ARE NOT for motobike's, just in case IF some1 already bought automotive oil.
#19 · (Edited by Moderator)
have a dig on Lougle Google as i dont know all the english words to explain it but:
Automotive oils are for Dry Clutch, hence they have all sorts of less friction particels etc on the oil. Those additives are harmfull for a wet clutch, especially on a high revving engines.
rev high, slipp the clutch alot and the additives that are slick make the clutch slip->get hot->cause overheating-> warp the metal plates-> and burn/glaze the friction plates.
the additives will d*ck into the friction plate as any oil does.
wet clutch designed oils have always additives on them that ADD friction, vice versa to automotive oils.
comprende ?
best gear oil ive used so far has been Motul5100 4T motorcycle 15W-50. because its the cagiva's original 15W-50 value and it defenitely made my mopeds rough gearbox very smooth. next im putting it to Cagiva's when my Agip is done.
#20 ·
on Friday I'm going to change the gearbox oil I've chosen Castrol power 1 4t 10-40w i don't no if its right or not but i have a question how do i change the oil as I'm trying to download the manual but the website ain't working so cant download the manual
#22 ·
me and a few mx racers at my club use automotive oil. weve been using vauxhall 10w-40 in my yz250 for years. Its cheap as sh*t. No trouble there. The bikes get ragged too.Tried castrol 4t in my supercity everyone on here has a hard on for and didnt like it. Had a small amount of slip at high rpm on changing up. So got the vauxhall stuff in now and its fine.
#29 · (Edited by Moderator)
Anyone confirm this, as my gearbox seems cak ... been over 2000 KM since last change, i thought they were good for 5k ..
The dealer who changed the oil last time use their own supplier as it were ..i looked them up, seemed like some sort of specilist oil company, anyway lost the link and name ...
I'm thinking of going for the Motul 5100 recomended on here .. but don't know which one because of the above query ...
When it had the change last time the gear changing was much improved, although that did not last to long, will going for the high end synthetic mean better changes for longer, or should one just swap the oil more often ..
I have these 2 in mind ... 1 litre enough ,, >>
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140344922187&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140344924151&ssPageName=STRK:MEWAX:IT
More noob sh*t from me i know,
but meh ...
#28 ·
i went to mme as ive booked to get the exsust and for him to directric my bike i asked him what oil i can use for my bike and he said to use 15 50 oil silkolin semi
#30 ·
#31 ·
Just stick some 10/40 4t castrol in. Job done.
